67panel said:yes he is a good bloke,did you see his clean room normaly some wonder and delight sitting on the bench.
sparkywig said:"They're top blokes, but only do things their way, take notice of what they say but keep a hold of your purse."![]()
Merlydog said:Oooooooo I just had my quote.... I think I may be looking elsewhere for my machine services.. Absolutely no problem with these guys at all by the way. They obviously know what they're doing and produce only quality engines. I'd defo still recommend them, just out priced me that's all.The Porsche engine he had sitting in his clean room suggests top of the racing range rather than what I'm after..
Back to the drawing board for me again... :roll:
alex4057 said:I would get them to balance the rods
and also bottom end:
Crank, flywheel, bottom pulley and clutch, balanced all togther as one spinning unit.
67panel said:WILL THEY CC THE HEADS AFTER?
67panel said:depends on cam ,I have a used ok 120 but that might be a bit bigger than you wanted.new stock should be ok with 110.
