'butchering some ply' you say? Mate, that looks a cracking job, quality workmanship!Today was spent butchering some ply, the Westy bed base to be exact.
Drop down door marked out. The bacon sandwich was very nice.
View attachment 9752View attachment 9753
The router came out for the edge trim slot in the panel and door.
I bought some American cherry veneer a while back just for this.
View attachment 9755View attachment 9756
Glued and clamped. Next job is trimming the veneer, a bit of oil to finish and then the edge trims can be glued on.
Thanks mate, it looks alright from where you are.'butchering some ply' you say? Mate, that looks a cracking job, quality workmanship!
That's why I cut it out of one piece of veneer.Nice touch how the wood grain pattern matches up.
Really like that solution for the fuel tank (looks lovely work as well!) - would have much preferred to put mine then if I didn't have the second battery in that location.Diesel heater fuel tank arrived and has been fitted.
That was a nice easy job that took most of the day because someone had previously bolted a remote oil filter housing under the battery tray.
I was going to fit another battery there and then get a wedge shaped tank made that fitted in front of it between the spare wheel well and wheel tub.Really like that solution for the fuel tank (looks lovely work as well!) - would have much preferred to put mine then if I didn't have the second battery in that location.
@sparkywigI was going to fit another battery there and then get a wedge shaped tank made that fitted in front of it between the spare wheel well and wheel tub.
Ozziedog,,,,,,,,,welcome to the clubThe bad news is that the horn now doesn't work.
If only we knew a great eeeeelecticianwho might fix all these dodgy hooters.My horn don't work either if it's any consolation..............na thought not![]()
